Making a Morgan By Andreas Hensing
#1 Message par TOK258 » ven. 20 nov. 2015 11:18 pm
ça vient de sortir, commandé sur la zone (meilleur prix : 32 £ livré) : http://www.amazon.co.uk/gp/product/184584873X
Making a Morgan
17 days of craftmanship: step-by-step from specification sheet to finished car
By Andreas Hensing
28.5 x 24cm • 160 pages • 380 pictures
ISBN: 978-1-845848-73-6
More here : http://www.veloce.co.uk/shop/products/p ... 9f4d25b0df
or here : http://www.ebay.fr/itm/Making-a-Morgan- ... 2177192454
Re: Making a Morgan By Andreas Hensing
#2 Message par hasta-la-vista » sam. 21 nov. 2015 10:45 am
ça doit être intéressant et je crois que je vais le commander
#3 Message par mogy37 » dim. 22 nov. 2015 2:18 am
j'aime bien la table des matières, ça me pousse à réfléchir
sur l'ordre et la durée des choses voyez vous,
rapport à des expériences de reconstruction vécues.
Si quelqu'un a des infos sur "Day 6 The scuttle panel" page 90 ...
Day 1 Where it all begins: chassis shop 46
Specifcations 47
Our story so far ... Conversation with Nick Baker on what happens after an order is received 48
Steve Morris – the chieftain 50
Brett Burbeck – the perfectionist 50
Chassis Shop 51
Machine Shop 52
Chassis Shop II 56
Break time 59
Independent front suspension 61
Day 2 The chassis is put on wheels 63
Wood Shop 68
Vince Wanklin – bedrock of the wood shop 69
Day 3 ‘The elbow’ – or: small cause, big effect 71
A digression: From ordinary plywood to exotic wooden dashboard 75
Day 4 The wooden frame is finished 78
Just a word with Graham Chapman on ‘quality’ 81
Sheet Metal Shop (aka the Tin Shop) 82
Day 5 Sheet Metal Shop – second day 84
Richard Harris – the ‘Tin God’ 85
The press brake 86
The first work week – our story so far 89
Day 6 The scuttle panel 90
A digression: production of the 3 Wheeler 94
Assembly Shop 96
Jason Hallett – the golfer 97
A visit to Superform Aluminium in Worcester 99
Day 7 Looking like a car now 102
Marcin Olszewski – the Bonneteer 105
Philip Jones – the Electrician 107
Day 8 Connection works 109
Mick Bishop – the athlete 113
Kevin Bunn – the career man 114
Paint Shop 114
The colours of Morgan – an agony of choices 116
Day 9 Paint prep work 117
The Cole family – the ‘real Morgans’ 120
Day 10 Paint Shop 121
The second work week – our story so far 123
Day 11 Third day in the Paint Shop 124
Day 12 Trim Shop 128
Leather for the Morgan 131
Day 13 Trim Shop II 132
Day 14 The soft top 136
Ben Jones – the racer 137
Tonneau cover 138
Electrics and small parts 140
Day 15 Finishing touches 145
Test drive 146
Day 16 Underseal 150
Day 17 PDI 152
sukram
#4 Message par sukram » mer. 25 nov. 2015 7:38 pm
Je dois dire c’est le meilleur livre sur le Morgan que je connais. :P
Je suis passe plusieurs fois dans usine, je me suis directement senti a l’usine avec ce livre :shock: , en plus les personne très bien représenter.
Malheureusement il n y a pas un éditeur pour la version français, peut être vous connaissons quelqu’un.
J’ai lu le en allemand !
Morgan 4/4 1985 - 2,0 Zetec
#5 Message par CBY » mar. 26 janv. 2016 7:36 pm
Ce livre en Anglais est intéressant et rappellera des souvenirs à ceux qui ont visité l’usine et permettra aux autres de découvrir les principales étapes du montage.
On a droit au traditionnel historique de Morgan sur les 45 premières pages, soit quasiment un tiers du livre avant d’arriver au sujet principal.
C’est une apologie à l’aspect artisanal de Morgan, avec parfois un récit un peu naïf si l’on se place sur un plan industriel et technique. L’auteur est enthousiaste, nous le sommes aussi, quoique...
On a quand même un peu de mal à comprendre que Morgan soit obligé de faire du spécifique sur chaque modèle, découpant à la demande le capot, les ailes, etc... et n’ait jamais eu la volonté de fabriquer des éléments avec des tolérances les rendant " standards " et facilement remplaçables. Voir l’épopée " remplacement d’un châssis de Roadster ".
L’auteur ne semble pas toutefois être très " technique " et l’on trouve quelques passages troublants :
. il fait deux fois référence à un " steering damper ", amortisseur de direction
. page 57 " Next, the steering rack, along with the steering dampers, is attached to the front of the chassis "
.page 63 " At its other end, the steering column is joined to the steering rack, which also carries the steering damper "
Sur les photos, il ne semble pas y avoir d’amortisseur de direction, peut-être confond il avec les soufflets caoutchouc ?
Page 75 sur le découpage du tableau de bord : " Steve guides the machine head along the groove in the jig, as the machine cuts the contours – including cut-outs, such as those for the handgrips.
Il ne semble pas qu’il y ait de poignée de maintien au niveau du tableau de bord ? Ou bien est-ce le " tempory grip " qui est vissé page 76 sur le dos du tableau pour le manipuler durant les opérations de vernissage ?
Sur cette même page 76, la couche de remplissage du tableau de bord est poncée avec des grains de 20 à 1000.
Ce grain de 20 paraît très grossier : 120 ou 200 ?
J’aurais toutefois aimé quelque chose d’un peu plus technique, ne m’extasiant pas sur le pliage d’une rondelle dans un étau avec un marteau qui nous vaut une photo page 59 . Il y avait surement plus intéressant comme le montage des king pins ou le réglage et l'alignement du cross head.
Bon, c’est un livre sur les Morgan, donc je l'ai lu avec intérêt et passion, et je ne regrette pas mon achat, c'est une belle publication.
A propos, quel est le nombre d’heures hebdomadaires travaillées chez Morgan ?
Voir page 59 " Break time " ?
#6 Message par MOGRS » mer. 27 janv. 2016 9:46 pm
Les éditeurs exploitent un site internet: "Morgan News".
Le 6 janvier 2016 ils rapportent que, jusqu'à présent​, seulement un MTW ​(construit avant​ 2014​) présente un défaut​ du chassis​, probablement parce qu'il a été utilisé sur un circuit.
Les mots me manquent!
Yves
#7 Message par Yves » lun. 01 févr. 2016 9:01 am
Un bon bouquin pour ceux (dont je suis) qui n'ont pas encore eu la chance de visiter l'usine...
Yves
#8 Message par raphy » jeu. 04 févr. 2016 8:05 pm
MOGRS a écrit :Les éditeurs exploitent un site internet: "Morgan News".
Ils doivent avoir des trous de mémoires ...
Je connais au moins dix MTW auxquels l'usine à fait un changement de chassis ....dont le mien qui n'a jamais fait de circuit
#9 Message par runabout » ven. 05 févr. 2016 6:35 pm
La mémoire sélective ..... Ça existe dans beaucoup de domaine ou profession , la mauvaise foi également :D :D
#10 Message par MOGRS » sam. 06 févr. 2016 8:47 am
runabout a écrit :La mémoire sélective ..... Ça existe dans beaucoup de domaine ou profession , la mauvaise foi également :D :D
Je crains que c'est une tromperie intentionnelle, parce que j'ai trouvé le lien vers l'article du blog sur la page web d'un vendeur de voitures.
Une recherche de google: "chassis problems morgan" ne dure que cinq secondes:
ou "Chassis Breakages - Early Cars" sur TM (30.06.2014)
La réalité versus la relations publiques.
