Nouveaux volants de Lutz Leberfinger/Morgan Park
- MOGRS
Désolé, il y a seulement une édition allemande du magazine (Morgan-Post).Vampirex a écrit :Hello Rod,
Il n'y aurait pas une version en Français ou en Anglais des fois ?
Bing Translator:
The wooden wreath is 26-29 mm with Ø considerably thicker, now there are also without gloves a good grip.
The Morgan Park steering wheel is flattened slightly in the lower half of the circle. Compared with the standard 14 "There are approximately 15 mm more steering wheel Place for boarding and disembarking.Because the steering wheel is no longer around,.355 mm be the Ø across and
vertical 345 mm. The Clou: who it not white, it does not. For
3 We also build a Wheeler smaller version with 27/28 cm.
The wood rings are deliberately not riveted, but to separate coating with the steering control rim polished aluminium mounted. That allows the wooden parts with any damage relative easily repair or replace to
can.
The Alukranz is not overly coated,
Therefore, there is no vergilbenden
Varnish and the ALU can be placed at any time on high-gloss.
The parts are screwed, so can
one different heads
Select: E.g. Buttonhead slot,.
Flachkopf-slot, flat head with Hexagon socket, flat head Torx,.
Cross slot with flat or Buttonhead and what the DIN in M5x22 otherwise
so is her.
Who may suffer no screws or rivets, which turns simply around the steering wheel and it used in the version of "Plain Wood" - it has 2 quasi
Steering wheels in one!
The MPH is available in 4 basic steering wheel
-Colours: light - medium - dark
-black. On request, we can
almost every desired shade (E.g.)
(Mahogany...) stains or even
colored spray. One is scheduled
Version in root wood. Here too, we can adjust the hue to any existing wood dashboard or use special veneer.
Should at a Morgan from ca year 2000
-the version with the large pad plate for the first time a wood steering wheel built, the Assembly is
on the standard adapter!
Matching fairing parts for the
We deliver with adapter.
The exchange for an already existing such as Moto LITA steering wheel
can easily be made, because we have with a version
9 Holes and unlikelihood Ø.
A matching Horn button made of polished aluminium is also of
us available. The best (?) is
Finally, it is for the first time with
possible, one steering wheel the MPH
Morgan legally with a wooden steering wheel
to go, as can on request
We supply a TÜV approval. As some Morgan driver on it no
Value place, we calculate the TÜVGutachten separately.
